The rear drive resolver initial angle procedure, which is contained in the XPENG G6 Repair Manual outlines the required diagnostic and setup procedures needed to correctly establish resolver position data and support proper rear drive motor operation. Without these procedures, a technician may perform the writing process incorrectly, risking calibration errors and unnecessary rework.
- How to perform rear drive resolver initial-angle writing on the XPENG G6?
- Where to find the XPENG G6 rear drive resolver initial-angle writing procedure?
- What OEM information covers resolver initial-angle writing for the rear electric drive system?
- When is rear drive resolver initial-angle writing required?
- How to perform resolver initial-angle writing after component replacement?
To access the XPENG G6 Repair Manual, simply click on the link below. I have attached a screenshot below to help you quickly navigate to the Rear Drive Resolver Initial-Angle Writing Instructions. Once you find it, you can then print or save it.Please note that the year in the document is not the YOM but the document release date, so it covers the entire model range. Also note that the document applies to all countries where the model is sold, including China, South Africa, Singapore, the UK, Germany, UAE, Denmark, France, Australia, New Zealand, Egypt, Thailand, Brazil, Canada, etc.
