Replacing and commissioning the XPENG G6's rear electric drive unit is quite challenging if you don't have the correct OEM information. However, if you refer to the XPENG G6 Repair Manual, it provides relevant reference for completing rear electric drive replacement and commissioning after component removal, replacement, or configuration.
- How do you replace the rear electric drive on the XPENG G6?
- Where can I find the XPENG G6 rear electric drive replacement procedure?
- How do you commission the rear electric drive after replacement?
- What OEM information covers the Rear Electric Drive System Assembly replacement?
To access the XPENG G6 Repair Manual, simply click on the link below. I have attached a screenshot below to help you quickly navigate to the Rear Electric Drive System Assembly - Replacement Procedure. Once you find it, you can then print or save it.Please note that the year in the document is not the YOM but the document release date, so it covers the entire model range. Also note that the document applies to all countries where the model is sold, including China, South Africa, Singapore, the UK, Germany, UAE, Denmark, France, Australia, New Zealand, Egypt, Thailand, Brazil, Canada, etc.
