Replacing the rear electric oil pump can be complicated on the XPENG, especially for technicians without the correct OEM replacement information. We recommend technicians refer to always the XPENG G6 Repair Manual, which provides source-confirmed reference information relevant to replacing the rear electric oil pump.
- How to replace the XPENG G6 rear electric oil pump?
- Where can I find the XPENG G6 rear electric oil pump replacement procedure?
- How do I remove and install the XPENG G6 rear electric oil pump?
- Which OEM manual contains the XPENG G6 rear electric oil pump replacement procedure?
To access the XPENG G6 Repair Manual, simply click on the link below. I have attached a screenshot below to help you quickly navigate to the Electronic Pump Assembly. Once you find it, you can then print or save it.Please note that the year in the document is not the YOM but the document release date, so it covers the entire model range. Also note that the document applies to all countries where the model is sold, including China, South Africa, Singapore, the UK, Germany, the UAE, Denmark, France, Australia, New Zealand, Egypt, Thailand, Brazil, Canada, etc.
