XPENG G6 Rear Left Door Wiring Harness Assembly
This document helps you identify and inspect the XPENG G6 rear left door wiring harness assembly using appropriate factory reference. It supports targeted physical inspection, systematic tracing of suspected open or short circuits and verification of connections following repair. Without the OEM layout a technician may not know how the harness branches inside the door, where its connectors sit or what each branch serves. This can lead to misdiagnosis, unnecessary replacement of door components, missed harness damage, incorrect refitting, longer diagnostic time and rework.
The XPENG G6 Wiring Diagram helps answer these questions
  • What should you check before disconnecting rear left door wiring connectors?
  • How do you determine whether the rear left door wiring harness needs repair or replacement?
  • Where can you find OEM instructions for removing and installing the rear left door harness assembly?
  • How to avoid damaging connectors and adjacent wiring during rear door repairs?
  • How do you verify that the harness is correctly routed and secured after installation?
How to Access the XPENG G6 Wiring Diagram
To access the XPENG G6 Wiring Diagram, simply click on the link below. I have attached a screenshot below to help you quickly navigate to the Rear Left Door Wiring Harness Assembly. Once you find it, you can then print or save it.
Access the Xpeng G6 Database
