The XPENG G6 OEM documentation for the rear left door helps technicians establish the physical harness routing, identify documented connectors and trace relevant circuits during electrical diagnosis and repair. To enable diagnosis and repair the diagram provides circuit schematics, connector pinouts, wire colours, grounds, splices, and module communication paths. Without this documentation, technicians may misidentify the harness, disconnect the wrong connectors and overlook damaged wiring during inspection.
The XPENG G6 Wiring Diagram helps answer these questions
To access the XPENG G6 Wiring Diagram, simply click on the link below. I have attached a screenshot below to help you quickly navigate to the Rear Left Door Wiring Harness. Once you find it, you can then print or save it.
- What precautions should you take before inspecting the rear left door wiring harness?
- How to check for pinched, chafed or damaged wiring inside the rear left door?
- What should you inspect before disconnecting the rear left door harness connectors?
- Steps to determine whether the rear left door wiring harness needs repair or replacement?
- Access the Xpeng G6 Database
