XPENG G6 Rear Motor Wiring Harness Replacement
Relacing the rear motor wiring harness can be done easily by referring to the XPENG G6 Repair Manual. This document provides an OEM reference for the rear motor wiring harness, which aids XPENG technicians in locating the relevant information when replacing the drive motor harness. Without this OEM manual, the rear motor wiring harness replacement process can be performed incorrectly.
  • How to replace the XPENG G6 rear motor wiring harness?
  • Where can I find the XPENG G6 rear motor wiring harness replacement procedure?
  • How do I remove and install the XPENG G6 rear motor wiring harness?
  • Which OEM manual contains the XPENG G6 rear motor wiring harness replacement procedure?
To access the XPENG G6 Repair Manual, simply click on the link below. I have attached a screenshot below to help you quickly navigate to the rear motor wiring harness. Once you find it, you can then print or save it.
Please note that the year in the document is not the YOM but the document release date, so it covers the entire model range. Also note that the document applies to all countries where the model is sold, including China, South Africa, Singapore, the UK, Germany, the UAE, Denmark, France, Australia, New Zealand, Egypt, Thailand, Brazil, Canada, etc. See Also: XPENG G6 Battery Lower Guard Plate Replacement
