XPENG G6 Rear Right Door Wiring Harness Assembly
This diagram information shows how wiring harness is routed, clipped and connected. On an XPENG G6 the harness depends on the low-voltage supply from the 12V battery and DC-DC converter, so a rear door harness fault can appear as a window, lock, speaker, handle or side-sensor code that points away from the real cause and the manual’s SRS safety procedures apply if any airbag or sensor circuits run through the door. With the OEM routing and location information, you can find the connectors and fixing points, follow the harness through the door and inspect it along its length. Without it you risk replacing a motor, switch or module that was working, missing damage inside the hinge boot, refitting the harness incorrectly after repair and disturbing safety components without the manufacturer’s procedure.
The XPENG G6 Wiring Diagram helps answer these questions
  • What needs to be removed to reach the rear right door harness on an XPENG G6?
  • How do you remove the rear right door trim panel without damaging the harness on an XPENG G6?
  • Where are the connectors, clips, grommets and fixing points for this harness on an XPENG G6?
  • How do you access the rear door hinge boot to inspect the harness on an XPENG G6?
How to Access the XPENG G6 Wiring Diagram
To access the XPENG G6 Wiring Diagram, simply click on the link below. I have attached a screenshot below to help you quickly navigate to the Rear Right Door Wiring Harness Assembly. Once you find it, you can then print or save it.
Access the Xpeng G6 Database
