Identifying the correct high-voltage disconnect procedure for the XPENG G6 can be challenging without access to the OEM Repair Manual. Without this manual, you may lack the source-confirmed information required to safely disable the high-voltage system before carrying out repairs. The XPENG G6 Repair Manual provides a reference for the steps required to disconnect high voltage on the XPENG G6.
- How do you disconnect the high-voltage system on the XPENG G6?
- Where can I find the XPENG G6 high-voltage disconnect procedure?
- How to safely disable the XPENG G6 high-voltage system before repair?
- XPENG G6 high-voltage disconnect instructions?
To access the XPENG G6 Repair Manual, simply click on the link below. I have attached a screenshot below to help you quickly navigate to the high-voltage system safety precautions. Once you find it, you can then print or save it.Please note that the year in the document is not the YOM but the document release date, so it covers the entire model range. Also note that the document applies to all countries where the model is sold, including China, South Africa, Singapore, the UK, Germany, UAE, Denmark, France, Australia, New Zealand, Egypt, Thailand, Brazil, Canada, etc.
