XPENG G6 High-Voltage Disconnect Procedure
Identifying the correct high-voltage disconnect procedure for the XPENG G6 can be challenging without access to the OEM Repair Manual. Without this manual, you may lack the source-confirmed information required to safely disable the high-voltage system before carrying out repairs. The XPENG G6 Repair Manual provides a reference for the steps required to disconnect high voltage on the XPENG G6.
  1. How do you disconnect the high-voltage system on the XPENG G6?
  2. Where can I find the XPENG G6 high-voltage disconnect procedure?
  3. How to safely disable the XPENG G6 high-voltage system before repair?
  4. XPENG G6 high-voltage disconnect instructions?
To access the XPENG G6 Repair Manual, simply click on the link below. I have attached a screenshot below to help you quickly navigate to the high-voltage system safety precautions. Once you find it, you can then print or save it.
